time2roll
Sep 16, 2017Nomad
mike brez wrote:OK maybe time to make a mental note and not worry about it. Good ground does keep you safe and the PI will verify the ground is always good. Hard to find an intermittent issue. With nothing plugged in on those inverter branch circuits it would seem to point to an issue with the inverter and could well be normal enough.
Did as you said and everything is good......WTF.
I'm going to let it sit awhile go and check again. Unplug and plug in a few times and see what happens.
No insta hot and there is nothing plugged into coach outlets.
38,782 PostsLatest Activity: Sep 10, 2026
