mike_brez
Sep 16, 2017Explorer
time2roll wrote:mike brez wrote:OK maybe time to make a mental note and not worry about it. Good ground does keep you safe and the PI will verify the ground is always good. Hard to find an intermittent issue. With nothing plugged in on those inverter branch circuits it would seem to point to an issue with the inverter and could well be normal enough.
Did as you said and everything is good......WTF.
I'm going to let it sit awhile go and check again. Unplug and plug in a few times and see what happens.
No insta hot and there is nothing plugged into coach outlets.
Ran the two roof tops for a couple hours,fridge is running as it is always on,used some 12v to draw down batteries and they are charging,pluged some lamps and drills into outlets and all is still good. I forget to try and use the inverter.
At work until tomorrow night see if it's still good then and if so try the inverter.
38,782 PostsLatest Activity: Sep 10, 2026
