pianotuna
Aug 03, 2016Nomad III
Hi,
It sounds like a variation on the "cheater" cables that are sometimes used by 50 amp rv's when in a 30 amp park. The want a mere $700 bucks for it, including the installation kit. They get around the 30 amp main breaker by having a 20 amp breaker in their "box". I'd rather run a secondary shore power cord for say $30 bucks total?
http://www.pplmotorhomes.com/parts/rv-power-cords/jtb-power-solution.htm
Tinstar wrote:supercub wrote:
I use to have a 30 amp motor home. Under "just the right conditions" you could run both AC's, but that was rare, you certainly couldn't count on it. I did some research and found a box to install that allowed both AC's to run. I can't remember the name, but do some searching and I'm sure you'll find it. If I remember right the generator is wired like a 50 amp service so there's separate legs to each AC, and you split off one of those lines into this box and then plug into two separate outlets. I believe that's how it was, like I said can't remember, but it did work, and was somewhat easy to install.
It's called the Power Solutions Dual Power Adaptor.
