msmith1199
Dec 19, 2017Explorer II
Executive wrote:
Got your PM and responded. There are no pictures attached or showing on this post.
That said, simply go to a place that sells plastic rails, usually a mobile home parts place and grab a couple pieces of rail material, cut them to proper length and apply them along the edge of your coach. This will direct the water off to wherever you want it to go. Another "fix" is to determine where the water originates from. My coach runs all condensation from the three A/C units down thru the coach and out the bottom thru hoses attached to the units. You'll have to look at yours to determine if the condensation collects in a pan or whatever. If it collects in a pan, drill a hole in the pan, insert a hose plug ( see picture below) into the hole and attach a hose to the plug. You can then direct the water off the roof. For a more permanent fix, dicor the hose along the roof line and the back of the coach...good luck....Dennis
Or, leave it like it is and just go clean the dirt off every couple of months! :)
