rcyoung3's avatar
rcyoung3
RV batteries...how many?
The wife and I are getting a Damon Intruder 2001 RV in a week (36 ft). It has a 7000W gas generator.
Here's the catch...and the reason for my post....the wife has been in an electric wheelchair (which uses qty 2 12v 35A batteries ( maybe 120V 2A for 6 hr/day to recharge) for many many years. She also uses an oxygen concentrator (uses 125V 4A basically 24x7).
I am trying to determine how many "house" batteries i will need in the RV to cover our needs. The RV comes with 2 "golf cart" batteries (6V 200AHr), of unknown "quality". However, her medical equipment demands a considerable amount of power on a daily basis as noted above.
Now we plan to spend 99,9% of the time in parks with electric power initially, but I learned many decades ago to always have backups and even backups to my backups.
If one were using the "standard" amount of electrical ( what the average RVer would use) routinely, plus the extra outlined above, does anyone have a "guesstimate" as to how many batteries i should have in the RV ( assuming they are about 200 AHr 6V) for at least one day, if not 2-3 days (just to soothe my paranoia)?
  • You can carry oxygen bottles. Some are large enough to supply 2L/min over night. What rate of oxygen flow is necessary. I always had bottle in reserve.
  • Wife is reluctant to use "bottles".....first wife uses an electric wheelchair, and her mother used oxygen too "back in the day". The wife always got tangled in the canula back when she walked, and the wheelchair has a way of tangling up with cords, canulas, etc etc.
    Also, when we were in college, there was an "interesting" problem with oxygen tanks (at least the ones that are 5 ft toll + or -). Someone knocked a tank over down at the university hospital. It lacked a protective cap, so the on/off valve broke off. The tank took off, went through the hospitals basement wall, and buried itself 12 feet underground!
    Both those memories are just a little too vivid ;-)
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    Well you use the generator to recharge the chair so we won't include that
    Yoru two Interstate U-2200's or equal are what you need for the RV overnight.
    That leaves the Concentrator.. NOTE> have a bottle on hand just in cuss.
    4 amp at 125 volt is 40 at 12.5 so we will go with 40*25, why 25, simplifies the math. 1000 amp hours per day. or about half that overnight (Generator hours to generator hours) since you can only use half your battery capacity (Assumes DEEP CYCLE) we are back to 1000 amp hours
    4 pair of GC-2 would likely do the job. with a bit of assist from teh existing pair.. THe downside. that's gonna make a BIG dent in the cargo carrying capacity for that RV. You might do better to use bottled O2 when traveling. Use the concentrator only when generating
  • First,look for a more energy-efficient oxygen concentrator, one that is portable battery powered will use much less power.
    In general, with your loads I guesstimate 2 batteries per day, so 4 or 6 if you want 2 or 3 days. That's if you get a more efficient oxygen concentrator. With the power hog you have now, it's going to be ugly without shore power or generator.
    I have family on oxy too, and I agree with your thinking. Do not depend on any single point of failure. Have two oxygen sources and two power sources.
  • Generator is a good backup to shore power. If you want a "backup to your backup" I would get FOUR 6V golf cart batteries, all new.
    I would also suggest upgrading your inverter to a more modern inverter/charge/automatic transfer switch. With this setup you do not need a 12VDC converter, just a 12VDC distribution panel. Some even have an optional output to start a generator. There are several companies that make such a device, but I like Samlex because of their simple installation.
    Also, with a good house battery bank, you really need a DC-DC battery charger, for charging while you are driving. READ THIS !
    Basic rule of thumb, is two batteries for a 1KW inverter and four batteries for a 2KW inverter. Naturally four batteries will provide longer and direct 12vdc power, as well, so I'd go with four min.
    Finding a place to put the extras, is usually the problem, with any setup.
  • I would probably go with four GC2 batteries. If you really get stuck the generator can run 24/7/365 until you find power or install more battery. If you do start camping off-grid for extended periods I recommend 600+ watts solar. Consider an automatic start for the generator if the battery gets low on charge.
  • Got a chuckle out of your breaking the regulator off the gas bottle story. So how safe is it to drive. In others words what is more risky driving or exploding oxygen bottles.
