Old-Biscuit
Oct 16, 2015Explorer III
JulieB888 wrote:
Wow thank you Old-Biscuit! That's actually the manual specifically for my model. The manual that came with my fridge was for dozen other models.
I have a lower access panel and an upper vent. But the sort of fan that you're talking about, the kind that is integrated into the fridge, sounds like it would be difficult to install. Where would i get it? Does it have a specific name?
If you have a 'roof vent' and fridge is installed following the required clearances then you shouldn't need the fan.
Installing fan/thermostat control/wiring/cut off switch are best done prior to installing fridge.
Can be done after install but fan location would have to be elsewhere
12V DC computer fan is better than the OEM fan
Thermostat is available on line (Dometic #3104133.016 On at 130*F fin temp Off at 115*F fin temp.... LINK
