Old-Biscuit
Oct 16, 2015Explorer III
Old fridge DC wires........just 2 wires?
Have you verified which wire is POSITiVE and which wire IS NEGATIVE?
Did you connect them POS to positive terminal and NEG to negative terminal on fridge?
The FAN is not complicated.......you removed and installed another fridge you can install connect a fan
BUT as I stated earlier.....if you have ROOF VENT and fridge clearances are correct you should NOT need the fan.
FANS are used when fridge is installed in slide outs
