OK, so all I got is a 15A setup, altho sometimes I plug into higher amp with a converter hoodgie plug. At RV parks I rarely trip the circuit using too much as I turn off the heat/AC when using the microwave, coffee maker, etc. But I can run the overhead heater with my quartz infrared heater when it is too cold, or, my little LG AC with my overhead AC when insufferably hot.
My problem is when I hookup at friends/family houses. Their outside service is not only pathetic, sometimes it is not a dedicated line so, for example, one friends son cames home late after work, turned on the microwave and blews the circuit. This usually requires me having to get into the house, into their basement to flip the circuit back on. Is there something I can get that I can set to blow at my plug so I can just step outside to turn it back on, or better yet, something to put between the plugs and electrical outlet inside?
