HVaughan's avatar
HVaughan
RV Refrigerator
I am a mechanical engineering graduate student and I am involved in a team project that is learning about the absorption refrigerator which is the type of refrigerator most likely in your mobile home. My team is needing end user feedback on the product of interest, so if anyone is willing I would be grateful to receive your opinion about the refrigerator. If you have knowledge of absorption refrigeration I would like to read your technical and non technical opinion, but if you don't know the theory I would still like your non technical opinion.
Thank you very much
  • Absorption refrigeration principal has been used since early 1800's
    Commercial production in early 1900s but were expensive $350-$600 OUCH!
    Make sure they are level when operated stationary. OK to operate while in transit.
    Use ammonia, hydrogen, water and sodium chromate mixture as coolant. Newer versions have replaced hydrogen with helium
    Takes 8-12 hrs. on initial start-up to properly cool down.
    Freezer gets cold first then food section can cool down
    Freezer can be cold and food section not get cold due to blaockage
    Don't place hot foods in fridge...best to pre-cool items first
    Can have difficulty keeping cool when outside temps are above 100*F and if below 32*F
    Can be operated on 110V AC power, 12V DC power or Propane
    Come in many different sizes/styles from basic to all the bells and whistles
    Can be care free/reliable or junk
    Most have been recalled
    Some have caused fires
    RV Absorption Refrigerator Homework
    LINK
    LINK
    LINK
    LINK
    Fire Info Link
    When you get thru reading the provided links you should be able to write a good summary. Don't forget 'credits/acknowledgements'
  • Absorption refrigerators are efficient users of electrical power, which powers the control unit, and propane (for cooling), but are slow to cool down from startup. Adding fans, both inside and outside, will improve efficiency and uniform cooling. Since RVs are frequently used where electricity is limited to batteries, household type (using a compressor and Freon) refrigerators are impractical. If an owner has a large enough coach with a large (six or eight 6 volt batteries), and is willing to recharge this battery bank frequently, then a residential type is preferred.
  • We have to use a fan in it to get the air to move (why don't they build them with fans???). I get tired of food that shouldn't freeze being pushed back against the coils and freezing. I had to toss carrots today....VERY irritating!
  • The absorption fridge in our previous Class A worked fine for 19 years, and still works well as far as I know. The 13 year old absorption fridge in our current Class A also works well. Both of them benefited from aftermarket internal and external modifications to optimize air circulation.
  • Pulled it out and put in a residential. Less Sodium Chromate means the cooling units are lasting a shorter time so why bother with then anymore.
