Tommygunns11
Dec 26, 2024Explorer
RV repairs
I have a 1994 a winnebago brave 24’ and need someone’s opinion on this. I’m not getting fuel to the TBI carburetor on the Chevy 454 motor. I have changed the fuel filter the fuel pump rebuilt the ca...
Did you try the OBD (on-board diagnostics)?
No what’s that?
Depending on wether you have OBD1 or OBD1.5 the data available on a 1994 is limited (compared to more modern vehicles), but none the less it is always a good place to start (I.e: the easiest first). Other than that with the air cleaner off when you pump the throttle does it squirt gas in the carb? When you pull a spark plug and ground it does it spark?
I have no idea what you have checked, but as far as I can recall, an OBD from back in the day might likely diagnose an ECM problem.
Thanks again and there’s spark at the plugs but no gas squirting out at the TBI carburetor. So I added another inline fuel pump just to see if that would work because the one that’s in the gas tank I’m told is only six months old. I got it to start but it immediately dies. I’m going to have a diagnostic done on it, a guy quoted me a 150.00 to do it then went up to 280.00 before he even came out and I got mad and canceled. I’m on a limited budget right now
