Tommygunns11
Dec 26, 2024Explorer
RV repairs
I have a 1994 a winnebago brave 24’ and need someone’s opinion on this. I’m not getting fuel to the TBI carburetor on the Chevy 454 motor. I have changed the fuel filter the fuel pump rebuilt the ca...
TBI so it has what looks like a carburetor but there are two injectors in the throat. Check the fuel lines from the TBI back to the firewall. See if there's a schrader valve on the line that you can depress and see if fuel spurts out. If no valve you'll probably have to figure out how to get the fuel pump running constantly. Then while the pump is running crack loose a line at the TBI and see if fuel comes out.
