Tommygunns11
Dec 26, 2024Explorer
RV repairs
I have a 1994 a winnebago brave 24’ and need someone’s opinion on this. I’m not getting fuel to the TBI carburetor on the Chevy 454 motor. I have changed the fuel filter the fuel pump rebuilt the ca...
If I had to guess your in tank pump went bad and is now a restriction to the external pump. Since you have an external pump can you re-route the external pump intake to suck fuel out of a 5 gallon gas can? Providing your main tank is not full you can leave the return in the main tank so you're only dealing with one hose. Then see if the truck will start and keep running. Of course it will matter if the external pump is rated for enough flow and pressure to operate the engine.
