toedtoes
Sep 14, 2014Explorer III
Will you be financing? A lot of banks/credit unions won't finance an RV that is over 10 years old. That could make your decision for you as to which way to go.
If all you're wanting to add is the 10amp concentrator, maybe you could simply add a 15 amp (household) power outlet and cord. I think you are more likely to find pedestals with one 15 amp and one 30 OR 50 amp hookup (rather than 2 - 30 amp or 1 - 30 and 1 -50 amp). This would likely require little work as you could install the outlet on the inside, install a male plug on the outside (directly opposite the outlet) and then run an extension cord from the outside male plug to the pedestal. And you wouldn't have to worry about needing adapters.
38,782 PostsLatest Activity: Aug 31, 2026
