swwyld12
Sep 15, 2014Explorer
Wow, this is a lot of good perspectives! To be honest, I do not mind running a separate cable for each setup, but I am concerned about the management of each of the CG's with regards to their acceptance of the presence of a second cable. Should the second cable be inadvertently unplugged, it is not a big issue, but I would be worried about them not allowing me to plug it back in, and being forced to utilize the available circuit in the MH. Because of this, I think a 50 amp rig would be better (even if the amperage is not needed, it will provide piece of mind that I will not need to have an awkward encounter with the management).
My final question is this: As I look, there is a fairly big array of units available. So, I was wondering your opinions on these options:
1) Private Seller vs Dealer (with a private mechanic inspection for either)
2) It appears that I can get a unit that is newer with a good bit of miles or an older one with lower miles. Do you have a preference which you prefer? In other words, is it better to have a newer unit that has moved more or an older unit that has been more stationary? I know that maintenance is a primary concern, but lets assume that both are equally maintained.
3) Is there anything else you think I should know when starting to look at rigs?
Thanks again to everyone!
38,782 PostsLatest Activity: Aug 31, 2026
