Gjac
May 28, 2014Explorer III
I would saw the broken bolt flush to the ball joint drill, tap, an insert a stud like the old carb studs to attach to the manifold. If you screw it up you won't loose anything. Looks like the tie rod ends are the same as another option maybe a broken one is available at a junk yard or another rver .
38,766 PostsLatest Activity: Jan 10, 2026
