TomKat08 wrote:
Own a 2002 Fleetwood Fiesta 31'. Ford F53 chassis. Prior owner had just replaced the tires. The tires are: TOYO M143 225/70R19.5. The tag on the driver side door says inflate to 80 PSI. The sidewall on the tire says 110 PSI. I'm driving them at 90 PSI.
As always thanks in advance for your continued advise.
Yes 90 psi will make it ride hard, at the size and weight of your RV 80 psi is all you need, you could even run 76 lbs in the front for a softer ride and tires will not run hot.
Just don't run any of those tires in the low 70's range.
