klutchdust
Oct 09, 2015Explorer II
Im confused. Are you using a prodigy brake controller? And you are towing a trailer correct.You mentioned a car. First off issues with lights on a trailer not
functioning that have before is usually a ground wire problem. My experience with not being able to get my gear shift out of Park on my E-450 was the brake light
switch under the dash. Once you hook the trailer and try to move it you say the brakes are locked, is the emergency cable that connects to the trailer battery pulled out
and stuck, therefore the trailer brakes are on. HAs the trailer cable been damaged in anyway.
38,763 PostsLatest Activity: Dec 05, 2025
