bobndot
Oct 05, 2020Explorer III
I copied a post from another person having the same issue.
It worked for me as well when my Atwood did the exact same thing. Also, using electrical contact cleaner would be a good idea.
Update: After talking to you guys, I went out and removed the wires going to the circuit board. There was a green wire which was ground, a red wire coming through the top of the heater and another red wire going to the igniter. I pushed them on and of 3 or 4 times on each pin hoping to clean them. I then lit the burner. It stayed on for about 3 or 4 minutes. Longer than before. So I did it again except this time I connected them on and off for probably 15 times. It appears now the heater is working. I moved the thermostat towards warmer and it clicked and the burner shut off and the pilot stayed lit. I then moved the thermostat to the hotter side and it started. Hopefully my problem was just corrosion of the terminals.
