CarlGeo
Jul 12, 2015Explorer
I have a DP on which I installed a Safe-T-Plus primarily for the safety issue in case of a blow out, BUT after installation the handling was much improved. Much easier to steer and maintain control.
I know my chassis and yours is quite different, but I installed mine in less than one hour. Easy, easy installation. It took two or three tries to get the straight ahead setup correctly, but that is just a little trial and error. Not hard at all. If you are reasonably good at mechanical work, you will not have any trouble installing it yourself!
38,774 PostsLatest Activity: Mar 01, 2019
