Desert_Captain
May 25, 2021Explorer III
No mention of your tire pressures... Get the rig weighed loaded as you normally travel and then check the load/inflation tables from your tire manufacturer. Nothing else can give you the right pressures for your your rig. Ignore the door sticker and the max psi on the sidewalls.
Most Ford chassis Class C's can be cured of any ride and handling issues by doing a proper alignment to include upping the + caster and simply inflating your tires for the load they are actually carrying. At just a year old your original shocks should still be fine but down the road {so to speak} plan on upgrading. I went with heavy duty Bilstein's and they have been awesome.
Good luck!
:C
Good luck!
:C
38,783 PostsLatest Activity: Sep 21, 2026
