- pianotunaNomad IIIHi,
I had a steel wheel roller made up to fit the hitch receiver. It helps greatly.
You might consider adding air bags to the rear that may gain you 3 inches.
I went to oversize (taller) tires which gave me 2 extra inches. - dicknellenExplorer IIYour receiver hitch receiver is the lowest point and I think they also have a roller like above that will slip into your receiver. Dick
- RoyBExplorer IIIf the clearance needed is small something like these skid wheels may work for you. I would do a slow drive doing this...
Google image
These skid wheel rollers are made by ETRAILER...
Roy Ken - DrewEExplorer IIIMore important than the absolute steepness of the driveway, of course, is how sudden the transition is.
I agree with carringb that doing a slow, careful trial run before making any modifications is only sensible. I would tend to advise against a significant lift (and I think 5-6 inches is pretty significant), if only because it will make getting the RV level at most campsites very difficult. You'd have to put 5-6 inches of ramps or other lifting under the front to get level on a dead level campsite, and that's a lot of ramps or blocks or jack extension.
If you only need an inch or so, air helper springs might give sufficient clearance without any real suspension changes. - carringbExplorerNot a problem at all, just beware with that much lift you may have to check the caster on the front axle afterwards.
That said, my brother's driveway is ~25%. His Forester 30-footer, with a short wheelbase and monster overhang, somehow makes his driveway!
Try it first. You might only need a couple 2x8's if anything
38,766 PostsLatest Activity: Jan 10, 2026
