blue_seeker_1's avatar
Jan 27, 2017
Safe to have rear suspension lifted for clearance?
I just purchased an 05 Jayco Greyhawk 31 ft. my driveway from the road to enter the driveway is steep, I'm not sure my rv will make the grade up. How safe is it to raise the rear suspension 5-6inches?
  • Hi,
    I had a steel wheel roller made up to fit the hitch receiver. It helps greatly.
    You might consider adding air bags to the rear that may gain you 3 inches.
    I went to oversize (taller) tires which gave me 2 extra inches.
  • Your receiver hitch receiver is the lowest point and I think they also have a roller like above that will slip into your receiver. Dick
  • RoyB's avatar
    RoyB
    Explorer III
    If the clearance needed is small something like these skid wheels may work for you. I would do a slow drive doing this...
    Google image
    These skid wheel rollers are made by ETRAILER...
    Roy Ken
  • DrewE's avatar
    DrewE
    Explorer III
    More important than the absolute steepness of the driveway, of course, is how sudden the transition is.
    I agree with carringb that doing a slow, careful trial run before making any modifications is only sensible. I would tend to advise against a significant lift (and I think 5-6 inches is pretty significant), if only because it will make getting the RV level at most campsites very difficult. You'd have to put 5-6 inches of ramps or other lifting under the front to get level on a dead level campsite, and that's a lot of ramps or blocks or jack extension.
    If you only need an inch or so, air helper springs might give sufficient clearance without any real suspension changes.
  • Not a problem at all, just beware with that much lift you may have to check the caster on the front axle afterwards.
    That said, my brother's driveway is ~25%. His Forester 30-footer, with a short wheelbase and monster overhang, somehow makes his driveway!
    Try it first. You might only need a couple 2x8's if anything
