slickest1
Dec 15, 2015Explorer
I have the same problem. The seal is shot between the two panes allowing moisture in. I carefully and I mean carefully drilled a couple small holes between the panes on the end that opens. I then hold the hair dryer toward those holes and it will clear the moisture. The glass will be stained or etched but you will still be able to see out. It is a very temporary fix. I still want to get mine fixed or replaced permanently.
38,781 PostsLatest Activity: Aug 12, 2026
