dougrainer
Apr 29, 2015Nomad
MagillaGorilla wrote:
Is there a thread on the bypass process? I don't want to bypass mine but I do want to know how just in case I need to.
FIND your solenoid. Have someone turn the switch ON and OFF while you go thru the various battery areas and compartments listening for the clicking of the solenoid. Once you find the solenoid, all you do to bypass is either have a 10 inch long 2 or 4 gauge battery cable with ring terminal ends and install to the 2 large posts, or if you have enough slack and post length, take the cables loose from one side and install on the other side of the 2 large solenoid posts. Doug
38,782 PostsLatest Activity: Aug 31, 2026
