KnowNuthin
Sep 01, 2013Explorer
96bounder wrote:Snowman9000 wrote:
the beauty of using the existing luan, and contact cement, is the instant bond.
If possible I would of left the existing luan but I had several spots that were coming apart.So basically I stripped the walls to good material and rebuilt it from there
I pulled away quite a bit of the old plywood/'wallpaper' with just my fingers... literally crumbled in my hand...
The section that is bad is a vertical strip about 2 feet wide running from the roof to the floor... I've got some Luan from HD... plan on using a 3 foot wide panel... anchoring one end to the good stud at the rear corner (adhesive and screws) and running about a foot overlap with the good/OEM wallboard... probably just adhesive on the overlap... adhesive all along the middle too where it would only be glued to the foam board...
38,782 PostsLatest Activity: Aug 30, 2026
