Yellowboat_
Mar 26, 2016Explorer
Yellowboat. wrote:
I had the same problem with our 2016 Sightseer 33C. I could not access the back of the radio without taking the dash apart. We were taking a shake down cruise prior to returning for warranty fixes.
I removed the heater vent and disconnected the heater duct hose to gain access to the back of the radio. I felt around and discovered that the satellite antenna connection was in the proper hole but not fully seated. I pushed it in fully seating it. It has worked fine since then.
I had my dealer double check the radio in a warranty visit and they said that everything checked out. JD
Update. What I thought was the antenna was instead the mike. I once again removed the heater vent and duct and I found the black box. I have secured the antenna with a tie wrap around the box. Tomorrow I will see if this fixes my antenna searching problem.
Safe travels. JD
