I need something to stabilize my 32' Class C and am considering attaching scissor jacks to the rear. Can they be used on Class C's? Also saw Saveajacks that looked interesting. Any thoughts?
That's the problem with hydraulic levelers on a Class C. The frame is narrow, so lifting one side lifts the other nearly as much. What's worse, the hydraulics are also somewhat toward the center of the coach length-wise. So lifting the rear also has a tendency to lift the front. Scissors jacks should help a lot if you can get them to Corners. Not quite so much if contact points are limited to the chassis rails.
