MrWizard
Aug 11, 2016Moderator
Most RV furniture is bolted not screwed to the floor
The bolts go all the way thru the floor, to large washers and nuts inside the compartment, or under the floor outside
Where do you intent to place this desk
Is there an open space or are you removing something
In a slide out? What's underneath
No slide living area should be clear of wires and plumbing, but may contain hearing vents, or Aqua Hot lines If you have that option in the RV
