EMD360 wrote:
So I don’t need the sea foam at all unless I wanted to clean the generator. We are leaving Feb 12th. I have no idea how to draw sea foam into just the generator. Thanks for the tip but that will take way more study. Guess I’ll just keep the sea foam for next year. And buy two more cans then. And put it in before I fill up. Good advice.
Just remove the hose that draws from the tank and insert 3 ft of the same ID hose into a can that you can mix the Seafoam with gas. Seafoam will keep the carb from gumming up over the winter months as will Stabil and other products. I like Seafoam because it does both. You are not talking years of non use only over the winter months.
