Gjac
Mar 12, 2014Explorer III
If you are going to remove and seal underneath make sure you put caulking into the screw holes first and let it set up. Then put caulking on the screw threads before tightening down. I just used the 5200 on a boat it is about $20 a tube and will bond, seal and fill holes at the same. It dries hard and will have to be cut to remove the bond. From reading your post it sounds like the screw holes are enlarged and that is where the water is leaking from. Once you remove it you may find rotted wood underneath that will have to be replaced first.
