deaop01
Mar 12, 2014Explorer
I had a leak in my ladder on the roof. What I did was take the bolts out and found two of them were rotted out. I moved the mount out of way and drilled the holes out to good wood. Don't go deeper than the screws.
I then used wood dowels and epoxed them in the hole. After they set up ( next day ) I put the mounts back and screwed the old ones down. Drilled the dowels so new screws fit nice and screwed them in.
Used eitherbond tape to cover everything up and self leveling dicor to seal the seems. Three years no leaks.
Hope this helps.
Ron
Hope this helps.
Ron
