Denver9's avatar
Denver9
Seat belt problems
Just returned from a looooong trip across the United States and back in my recently acquired 1993 , 27 ft Class C motor home. It is a Majestic, built on a Ford E-350 chassis.
The only problem I had was leaking window seals in the rain and the driver's side seat belt.
The belt barely pulls out enough to fasten around my waist when it decides to allow it. Right now it is about 3 inches too short to allow proper fastening.
Apparently the belt is stuck somewhere in the retraction mechanism.
I cannot readily see how to remove and disassemble the mechanism for repair.
Any ideas or suggestions ?
-Denver
  • Hemi RT wrote:
    You are not allowed to disassemble the seat belt mechanism,
    Also, you're not allowed to drive drunk, exceed the speed limit, text and fail to stop at stop signs, etc.,.......... but. ;)
  • You are not allowed to disassemble the seat belt mechanism, sounds like the belt is twisted inside. You may have to nurse the belt out, remove the twist and roll it back into the mechanism, otherwise you will have to replace it with a new or working good used one
