fourmat
Jan 15, 2016Explorer
Cbones wrote:
Nice job. Did you replace the foam? How difficult would you say the whole job was?
No foam was fine just lousy material
Took me 3 1/2 hours per seat after removed from motorhome.
Only special tools you need is a no.2 square drive screwdriver,hog ring pliers and rings. It is not that difficult but you have to take your time and be careful cutting holes for arm rest and recliner.
Arm Rests are a hard to get screws lined back up after you remove flex steel name plates. Removing seats from motorhome is easy 4 bolts and 2 seat belt bolts you have to remove armrests to get them out the door takes about 10 min ea
38,782 PostsLatest Activity: Sep 02, 2026
