kemer's avatar
kemer
Set up Order
Is there a preferred order when setting up? I read that the unit should be level before extending slides. So I've been doing the auto-leveling first, until the monitor says "success" and is level. Then extending the slides. I've found that after extenting, the unit tilts slightly to the left(where I have two slides). Would I be better off extending slides first, then running the auto-level? I realize that the most important thing to have level is the Refrig. I'm guessing that if the site is basically level, extending the slides first, then leveling should work.
THANKS.....
