Is there a preferred order when setting up? I read that the unit should be level before extending slides. So I've been doing the auto-leveling first, until the monitor says "success" and is level. The...
Follow YOUR mfgs recommended way of extending the slides. All Monaco coaches recommend you extend slides THEN level. As stated above, this ensures the rig is square before leveling. Monaco also uses a three point leveling system which may have something to do with their recommended procedure....follow your mfgs recommendations. They've spent the big bucks for the engineers to form an opinion as to the correct method...Dennis
