Nomadac
Jan 19, 2015Explorer
owenssailor wrote:
Running engines every month seems to me to be an idea especially prevalent in the RV community.
There are many thousands of boats both gas and diesel powered sitting on shore in the cold parts of this continent. There is no way they can be started and run every months for 20 minutes under load. They are all fine in the spring.
Farmers store all kinds of expensive equipment every winter. Most of it is diesel powered. You can bet they don't take their combine out for a spin once a month.
Millions of dollars worth of construction equipment sits all winter. I don't see paving machines out for a tour in Feb.
Use the correct storage additive in the fuel. Charge and disconnect the batteries. Come back when you want/need to use the machine again.
x2 I do run my gen once a month under a load, which is what Onan recommends.
