camper19709
Feb 06, 2016Explorer
Old-Biscuit wrote:
You fill your fresh water tank and then use the pump.
Then as needed you add more water to fresh water tank
If you leave CG water supply hooked up and set to fill your fresh water tank WILL overflow....there is no float/shutoff in/at tank.
YOU are the control....manual
This is what I do. Continually using the fresh tank keeps the water from getting stale.
