tropical36
Feb 14, 2016Explorer II
JCat wrote:
My water pressure at my winter park is low 40 PSI and does not supply enough supply to my kitchen sink or bathroom sinks.
I have talked to others about their water flow and many don't use the parks supply. Their RV's always use the water pump for pressure.
My RV has a valve where I can select to fill my fresh tank or use park pressure.
I wondered if I can change it up so that the fresh tank would fill and not overlfow and then use my water pump to get the proper pressure as the other RV's do ?
Anyone done this type of conversion ?
If yes how ?
These problems usually disappear with removing any built in pressure restricter and using only a whole house pressure regulator for shore water.
No way, I'm running my pump, while in a park.
