Johno02
Oct 07, 2015Explorer
We had the same problem, so I made up a short hose to go through the hole. Made it to be stretched just a bit when installed. I put a connector on one end, sealed with goop andclamped. attached that to the drain connector inside the bay. Stretched it through the hole, then installed connector on the outside end with goop and clamp. When released, it fits right up against the outside of the hole. A cap for the outside connector, with a retainer strap to keep from losing the cap. DW added two snaps and a velcro strap across the outside to hold it in place firmly. I would like to use hard pipe fittings, but the angle doesn't fit manufactured pieces, so I will need a roundtoit to make it fit. The flex hose has worked for five years so far.
