rockhillmanor
Oct 07, 2015Explorer II
Yup the hole in the bottom of the sewage bay is too small.
Also the cover for it does not stay in position. Don't even bother trying to use it.
And even if you had a hose that did fit thru it......
Think about it you would have to get on your knees to feed it in from the beginning end of the hose up to hook up. OR Feed the 'whole' darn sewer hose thru the hole from the top down. :R
The whole idea of using that hole in the bottom of the sewage bay for dumping is just ridiculous!
1. Cover that hole up!!
The cap (if you even have it)does not stay seated and dirt, road debris, critters etc get right into your bay thru that opening.
I got a square piece of hard plastic and screwed the corners down on the floor of the bay using real wide washers for a tight fit that covered that useless hole up.
2. Buy a rigid hino collapsible sewer hose.
Open bay
Hook up Rhino Sewer Hose to dump valve, run out the bay door and run to septic. Done. :W
Your coach will always be higher than the dump station so trust me it will dump out. The Rhino sewer hose will show it the way.:B
Open bay
