- PastorCharlieExplorerProbably built for the European market where everyone is left handed. :B
- kcmoedoeExplorer
Effy wrote:
Love the Macerator. However, your situation is different from the OP in that when yours came from the factory, all the controls and hoses necessary to dump were on the utility side of the RV. Apparently the rig the guy is looking at cannot be dumped from the utility connection side and to me that would be a deal ending problem. Still sounds like it was a modification and not a factory decision to put the sewer on the wrong side. If it was a factory decision, it sure was a stupid one and if they are so out of touch with how a rig operates that they would do that, I would be afraid there were other things in that rig that would be equally puzzling and stupid.
Some units are built that way, typically when the bathroom or toilet is on the passenger side. The ACE 29.2 is built like that and the solution (from the factory) was to install a macerator with the hose on the other side. The tank gate valves are linked via cable and the switch for the macerator is in the same bin. I love having the macerator and it makes things so much easier and cleaner. If you can have that setup installed you can dump from either side. Just install the macerator in the pass side bin and run the hose up over or around the tanks to a bin on the other side. A hassle to do but once it's done it makes things much easier. And with a macerator there is no dependence on gravity. You can run the hose wherever it's easiest as opposed to standard slinky lines which you have to be more creative about how/where to run it since it must have a downhill flow. - J-RoosterExplorer
DSDP Don wrote:
X-2
I doubt that Coachman built the motor home that way. A previous owner probably modified it for a piece of property where it was parked. It should be easy to return it to the other side. - bluwtr49Explorer III would probably pass on that issue alone. To big of a PITA and you would regret the purchase every time ol stinky had to be snaked under the coach to the connection.
- EffyExplorer IISome units are built that way, typically when the bathroom or toilet is on the passenger side. The ACE 29.2 is built like that and the solution (from the factory) was to install a macerator with the hose on the other side. The tank gate valves are linked via cable and the switch for the macerator is in the same bin. I love having the macerator and it makes things so much easier and cleaner. If you can have that setup installed you can dump from either side. Just install the macerator in the pass side bin and run the hose up over or around the tanks to a bin on the other side. A hassle to do but once it's done it makes things much easier. And with a macerator there is no dependence on gravity. You can run the hose wherever it's easiest as opposed to standard slinky lines which you have to be more creative about how/where to run it since it must have a downhill flow.
- kcmoedoeExplorerMy experience is different than the previous poster. I have never seen a park that had sewer hookups on both sides of the parking pad. There is no way the rig came with the sewer outlet on the passenger side, it has to be a home-made modification. If you are going to be traveling and using RV parks it would be a deal breaker if you couldn't get it restored to the original utility side position. Having to run your sewer hose under the rig each time you wanted to hook up would be a major pain. I would even think most parks wouldn't allow such a set up (assuming they knew, which they wouldn't) because there would be no way for you to "walk" the remaining waste from the outlet on your rig into the campground's sewer pipe. You would have to drag it from under rig instead, leaving a trail of waste across the site, nice touch for the next guest.
- rgatijnet1Explorer IIIWe have been to many campgrounds that have sewer hookups on both sides of the parking site as well as sewer drains at both ends and in the middle of the parking area. I don't think you would have any problem but it might be a good idea to carry a few extra lengths of hose with you.
When we travel, we only hook up to the the sewer drain one a week or so to empty our tanks so in most cases, where the sewer drain is located at most RV parks is not a big concern. If the floor plan is something you can live with, the sewer drain location would not be a deal breaker to me. - Golden_HVACExplorerHi,
I would also be checking the options to moving the dump to the other side. It should not be to difficult.
Are the tanks located on the passenger side or drivers side? Or in between?
You might find fittings here. Tank-Depot.com
Fred. - DSDP_DonExplorerI doubt that Coachman built the motor home that way. A previous owner probably modified it for a piece of property where it was parked. It should be easy to return it to the other side.
- amandasgrammaExplorerIt's a PITA, but it can be done. Our friends have one like that. Crazy that it would be built like that. It wasn't modified, he said it came from the factory like that. Extra long tubing is needed in case you don't find a "double" dump station.
38,769 PostsLatest Activity: Apr 03, 2026
