S-n-L
Jul 16, 2013Explorer
Thanks everyone,
Our Moho will have a macerator. I will wait to buy anything until I pick the unit up. Buying used from a dealer I know it will have some of this equipment already on board. If I do not like what is there I will replace with the recommendations I have seen here.
If you do have a macerator and use the small diameter hose, do you use a suspension device to elevate the hose or just lay it on the ground? Also, with a macerator does the gray water drain from the small diamter hose as well as the black water?
Stuart
Stuart
