et2
May 21, 2014Explorer
Sewer solution
I just purchased this for our MH as our dump connection is literally inches from the ground with the hoses attached. It's been a real pain trying to dump at times as I found myself walking the sewage down the hose to the sewer connection.
This system seems like it will fix this problem. My issue is the extension hose only has aluminum connectors to attach the hoses together - no hose clamps are included. Anyone who has used the extension, have you had any issues with the hoses coming apart without clamps? It seems like it could be a problem. Not to mention the hose connect to the pump doesn't have a hose clamp at the elbow at the end of the hose either. The only hose clamp it at the pump where the hose is attached.
This just seems like a accident waiting to happen.
