timpitt
Aug 16, 2023Explorer II
shifting on downhills
We have a 2021 7.3 v8 fleetwood bounder 33c. Does anyone have info on shifting when going down hill and up hill. Other than the Ford manual?
way2roll wrote:Does tapping the brake cancel the cruise control?
I don't know about the newer models but in previous versions that's what the tow/haul mode was for. When descending if you tapped the brakes it would downshift.
time2roll wrote:way2roll wrote:Does tapping the brake cancel the cruise control?
Or would the activated cruise control initiate a downshift on its own to limit speed?
wowens79 wrote:valhalla360 wrote:dodge guy wrote:
Should always be in Tow/Haul! Anytime the engine is started, turn it on.
This kind of baffles me. MHs should be set up to be in Tow/Haul as the default and you should have to turn it off manually if you don't want it for some reason. Same with trucks...the trucks know if a trailer is hooked up, so if it senses one, it should go into tow/haul as the default.
My F-350, once you put it hook up the trailer and put it in tow/haul mode, it stays in it when you stop for gas etc. Then when you disconnect the trailer it asks if you want to stay in tow/haul. I don't think I'd want my truck to automatically go into it. If I'm pulling my 14' jon boat, I don't want tow/haul. On a motorhome I agree, it might as well only have tow/haul mode.
obgraham wrote:
I think what Gritty is saying is, learn to drive the rig instead of having the rig’s computers drive you.
Don’t know about anyone else, but I’ve been driving since 85. I know how to drive manual transmissions and automatics. My Class A with the Tow Haul is the first I’ve had. It makes a huge difference when towing. Before this I always manually shifted my autos for down hill braking. After 38 years it’s nice to have a vehicle that will do this for me. I’m still watchful of the speed and rpm, but now I can concentrate on other aspects of driving.
wallynm wrote:
IMHO you should be in the gear going down hill that you would be in going up the same hill!timpitt wrote:
