mikhen wrote:
Well it's been a few weeks since I used RMP. I planned on adding this step from the start. I applied the 4 coats originally a few weeks ago. Used the RV, and let it set. This past weekend, I washed it using dawn, then I applied a final coat of RMP, just to even out any missed spots, etc. The result is great. And I found washing bugs off is real easy.
A tip for everyone new trying this....clean the window trim, door handle, etc very well. If you have black trim and there's any scratches in it, use a black sharpie to touch it up. The go ahead and RMP the trim. The result is a jet black trim that shines.
I took pictures, but when I went to check them and edit them, I realized I'm not a photographer. O well, our RV shines either way.
I did something similar. I did 4 initial coats. Then, after 3 months, I gave it a good wash job and added one more coat. Red Max is the Bomb!!!!
