bluwtr49
May 03, 2014Explorer II
I has the same problem when plugged into my garage outlet and finally figured out the MH and GFI were simply not compatible so I pulled the GFI and replaced it with a non-gfi.
No longer an issue though as I had a 50A RV outlet installed. I always found it interesting that a 20 A outlet had GFI but a 30A RV outlet does not. That sort of tells you something.
