diveman52
May 03, 2014Explorer
teddyu wrote:
GFCI should not be use to power an RV. The AC refrig and water heaters are prone to causing the GFCI to trip. Change to a non-GFCI receptacle. JM2ยข...
GFCI are used for a purpose to protect life and property.
Tripping GFCI are either indicating a problem or have become defective.
Us and ohm meter and check for continuity between the ground and neutral on the coach when not connected to shore power you should show no reading...
ie no continuity between the two.
