wa8yxm
Aug 03, 2020Explorer III
Well we ran the list
Using a volt meter check the output of the converter In my case that's as far as I got (Lift the battery negative lead first)
Then if you have 13.6 or better abd the Reverse Polarity fuses are good (if they are not you will have nothing) move out along the battery lead till it drops.. or test light goes out (Since the battery is not connected)
Problem exists between bright and dark
IF interior lights do hot work with battery negative listed The converter or RP fuses are most likely
