Headlesschicken's avatar
Aug 04, 2017
Should I Purchase An Older Moterhome?
Hello. My husband and I are thinking of traveling around the US for a year and are looking at several RVs with a budget of $25k. We found a 1994 Kountry Star that looks in good shape in the photos but are concerned buying one this old for a cross country trip. We are also looking at an 2003 Bounder. They are asking $13k for the Kountry Star and $24k for the Bounder. We have never owned a moterhome before. What are yalls thoughts? Is it a bad idea to buy a 94? Is the MPG going to be alot worse in a 94 vs an 03? Do you think parts would still be available if something happened in an 94? It has a 434 V8 and from what I understand it was a luxury model in 94. My husband is confident in his mechanical skills and feels he could handle some repair. Buying the 94 gives us money left in case something happened where as the 03 uses all our budget but I'm concerned something major could go wrong and use all our budget anyway. We would like to get some advice before looking at it as it is several hrs away from us. Do you think it's a waste of time to look at it and we should stick to a newer model? Thoughts are appreciated thank you!
Replies have been turned off for this discussion
  • Bill.Satellite wrote:
    Bounder is a Fleetwood product and they are still in business should you need support. I would not be concerned about purchasing an older coach but I would want to see maintenance records, verify that every applicance works properly and have a qualified mechanic look over the chassis and engine / transmission.
    The Kountry Star is a Newmar product, they too are still in business should they need any support. I will say when Fleetwood went bankrupt the new owners seem to have done a nice job supporting the older stuff too.
    The Newmar will have "better bones" and was a lot farther up the food chain than the Fleetwood.
    With that said, the '94 is getting some age on it for sure. Without seeing both first-hand this one is a tough call to make.
    To the OP, you can go to Newmarcorp.com and download the brochure on the Kountry Star. Go to the brochure archives and click on 1994 (obviously) then choose the Mountain Aire Class A brochure, the Kountry Star is in that one too.
  • Ivylog's avatar
    Ivylog
    Explorer III
    Unless the tires are less than three years old they will need to be replaced $$$$ especially if the rig has sat...not used often as you have no idea how they were treated. A 94 will probably only have a four speed tranny while newer will have six which will get better MPG. A newer may have a LR slide which will be appreciated on rainy days and will have better resale value.
  • There could be potentially many costly and dangerous concerns....AND......both coaches could be diamonds just waiting to be shined! We stepped out and bought a 1999 model about 4 years ago. It was very affordable to us, but most of all, we knew the people we bought it from and they had maintenance records to prove it was well taken care of beyond the cosmetic. Even so, we've put probably $8-10K in repairs and upgrades over the past 4 years since we bought it. Replaced brake calipers/hydraulic lines, front leaf springs, interior carpet due to roof leaks which took FOREVER to find, plumbing components that had cracked from age and were leaking. Slideout adjustments, electrical switches replaced. It's truly a shade-tree-mechanic's and a tinkerer's dream! And oh yes...tires!...first trip out we blew 2 rear tires due to their age....my mistake for not checking that.
    Not trying to scare you off from the purchase, but I DO say these things to help you make your decision INFORMED. An older coach is just that.....older. Just like us, things have a useful life expectancy and they wear out and will need replacing. As long as you are willing to accept that fact, you will be just fine. The fit and finish in motorhomes from some manufacturers should scare you off right away. They will just "FEEL" cheap. In others, the fit and finish will be great, but there may be underlying problems with places you can't readily see. These things are houses built on a truck chassis that rolls down the road over potholes and curves and all kinds of road hazards. They are going to break somehow, someway....in the case of buying a used motorhome, especially an older one, you WILL find problems. It's just a matter of how bad they are and how involved they will be to fix them. Check the records for frequency of oil changes, chassis lube, engine tune-ups, etc. Hoses, coolant, brakes. The usual for engine and chassis maintenance. It's not a lot different from maintaining a car....just bigger! Check the tire date codes. Tires on an RV tend to age out well before they wear out. 6-7 years old and you should be considering replacing them....especially if the unit has been stored outdoors and the tires were not covered. They might look in pristine shape as far as tread and appearance...but inside they may well have deteriorated from sitting in the sun and not being used. If the tires are old, you'll be looking at a couple grand investment or better right off the bat.
    Take your time, go over it from top to bottom, front to rear, side to side and any other way you can think of to look at it. Put it through tests yourself, don't just take the seller's word for it that it works.
    Good luck to you in this venture!!!
    X2
  • Bounder is a Fleetwood product and they are still in business should you need support. I would not be concerned about purchasing an older coach but I would want to see maintenance records, verify that every applicance works properly and have a qualified mechanic look over the chassis and engine / transmission.
  • Not sure of your comfort level, but you reach out today you may find a helper work you threw and give you a great sense of what is great and an someband what isn't
