How do you know the grey is not full?
When my grey is full, the shower (lowest) is the first to fill up. If I use sinks the water will flow just fine, but the shower tub will be filling higher while the sinks drain. Sounds like your grey tank IS full.
The grey dump sounds similar to mine. I always thought it was rushing at first cause it was full, then it slows, then the one way air vent kicks in (under the sink) and makes a big gas release sound ........anyway, your sounds just like mine
Maybe check those one way air valves under sinks?
